Old 07-27-2014, 04:25 PM
c69ss396 c69ss396 is offline
I had the same issue with mule drive belts, I tried several different brands and it would sling them off instantly. I put on a OEM CC belt and it work perfectly....
Old 07-27-2014, 08:31 PM
Darrell Darrell is offline
It doesn't matter. It is a NF deck.
HUH ???? What is the difference between a NF and WF deck ???
Old 07-27-2014, 08:32 PM
nothing, there the same
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-27-2014, 09:13 PM
The NF Decks are: 38, 42 & 48
The WF Decks are: 38, 44, & 50
Old 07-27-2014, 09:22 PM
And there is an early, and a late NF deck.
Pin on, and QA. They are different.
Old 07-27-2014, 10:11 PM
hdsdcouple's Avatar
well after some further testing:
It seems that the belt stays on and runs great as long as the deck is in the highest position. As soon as you let is down to cut the grass shorter it tosses the belt.
so many tractors, so little money
Old 07-27-2014, 10:17 PM
Is the deck tipped too far forward?
Old 07-28-2014, 04:22 AM
With the belt installed.
Set the deck at the height you want the grass cut, then step back, crouch down and look at the center pulley if the front of the deck is too low, or the back is too high, it will look like the pulley is running down-hill.
If this is the case, the pulley needs to be more inline with the belt.
Old 07-28-2014, 08:21 AM
Pin on and qa are about the only difference. My 108 wf has a 48" deck on it and my last mowing tractor was a 126 nf with a 44" deck so for those making it seem like there's huge differences in the decks there really isn't, the only real differences are in the undercarriage.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-28-2014, 11:48 AM
red56turbo's Avatar
I agree. The 1250 I had ran a 38 inch deck. I've seen quite a few 1x8/1x9's with 38, 42, and 48 inch decks as well.
Josh
Diesel Cub Cadets...........
