Old 07-27-2014, 11:41 AM
Nice find on the O,while you have it in the truck I would take it to the self serv car wash and rinse it off.
Good advice David.
Old 07-27-2014, 03:06 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Well back from the store. Got the O cleaned, engine oil changed, oil bath air filter cleaned and new oil, greased all grease points, repaired fuel line, installed new spark plug and then took it for a ride. It runs and drives great for being 52 years old. The engine oil was a bit over filled when I got it and the oil bath air filter was also over filled. When I took it for a ride after the work I just did, I noticed less smoke out the exhaust. Hopefully the over filled oil was the cause of the small amount of smoke out the exhaust when I first got it. Next today is the transaxle oil change, then I will need to check and adjust engine rpm, seems like full throttle is no where close to 3600 rpm.I got to say this thing is way cool. Most important my daughter loves it and wants to find a tractor show so she can go show it off.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 07-27-2014, 03:18 PM
glad your daughter is enjoying it, hopefully its a great way for you two to spend some more time together.
Pap's 100
Restored 108
1211 Dual Stick
1050
