Yep Cub used pretty much the QL engine mount in the 1210, 1211 ask me how I know.
For some reason, I would have thought that the 1210/1211 used the same style as the 1050 but the more I look around, the less and less I see the 1050 style mounts used. Guess you learn something every day, and it seems as though most days I learn it from this site!
-Ryan
so the verdict is my new ones for a 1650 will fit my 1211 right and also thanks for all the help
Only other option I can think of is solid mounts. One of out memebrs makes them.
http://www.onlycubcadets.net/forum/s...ad.php?t=20875 Scroll to pic # 9
I have QL mounts on my 1211 work fine.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
If your dead set on the rubber mounts, yes the QL ones will work on the spread frame models also. I say save the expense and go solid. No more fuss, cheaper.
then ill make out i got a new set for my 1650 about 4 years ago so ill use them thanks for saving me money and the info
