Old 07-11-2014, 02:46 PM
Ive been looking into having my rears foam filled like a skid steer tire, no more flats or checking the air pressure and it add's some pretty good weight, from what i read a 23x8.50 will be about 70lbs when filled.
Old 07-11-2014, 02:53 PM
I don't think the ride would be any good. I've looked at that, but they are harder when foam filled. Besides, with CaCL2 my wheels weigh in at 100LBS.
Old 07-11-2014, 02:58 PM
Yea i was concerned about the ride to but i was gonna do it to my winter plowing wheels first to see how it is. Judging by the last picture you put up i probably weigh 60 pounds more than you so my tire can weigh a little less.
Old 07-11-2014, 03:07 PM
Steve149's Avatar
Steve149 Steve149 is offline
Id hope not, they would be solid blocks of ice in the winter.
I hope not too that would be upsetting to say the least...I will keep you posted.
Old 07-11-2014, 03:09 PM
Steve149's Avatar
off topic but what do you recommend for antisieze on the wheel bolts? in the past I always used copper kote
Old 07-11-2014, 03:16 PM
I use the regular silver anti seize on everything but just about anything will work, if i dont have anti seize i just use a little red grease.
Old 07-11-2014, 03:17 PM
I'm pretty sure that foam filled tires on a Cub would beat the operator to death.
I used to occasionally run a rubber tire Hi-lift, that had foam filled tires, it was the same way.
Not sure if it's the geometry, the weight distribution or just the nature of the beast of a skid loader but you don't notice as great a difference in foam filled vs air filled tires as you do with other equipment. There is a difference, and you can tell it right away, it just doesn't seem as bad. (this is based only on my own experience... your mileage may vary)
Old 07-11-2014, 03:21 PM
Thats why i want to try it on my winter wheels first, once i put the chains on it rides like crap anyway.
Old 07-11-2014, 03:37 PM
Steve149's Avatar
I will use a little grease on them for now as I will be tearing the tractor down for a full restore here soon. Just want to get all this goofy stuff out of the way while it is nice out and the beer is cold!
Old 07-11-2014, 04:39 PM
Berwil's Avatar
Berwil Berwil is offline
My tractor sits in my unheated garage all winter with the snowthrower on it. Even this past winter it stayed above freezing in there, the po could have had a similar situation. Personally I still wouldn't use plain water, but just a thought.
Bill
