![]() Quote:
I take the block into get machined tomorrow night after work. I'm pretty excited about it ![]()
![]() Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978 Columbia City, Indiana |
You can do a static test. If it passes, clean off the rust with some sand paper or emory. Here's the link. Do other test after it's running.
http://www.onlycubcadets.net/forum/showthread.php?t=368
![]() Quote:
if it ohms out good, could I just clean the rust off the tops of the stator and be good to go....per say.
Pretty much.....
![]() Quote:
Also make sure the stator isn't shorted to ground before you put it back together. I never liked that Ohm test for the Stator. Such a small number and small range - better have a good meter and it better be well calibrated. Nice find! goodluck
- Tim 1872 60" Haban deck- 2082 450 blower, 50c deck - 1450,1650 2x44a deck, QA-42A snowthrower, 70 w/k181(destroyed) 38" pin on deck |
Cubby. By looking at the pictures it looks like the bore is waaaay to big to salvage unless it's an optical illusion and is there a big crack about 9 o'clock of the block? Looks bad to me?
Welcome to OCC
![]() A dirty stator with a little rust is common after all those years. It'll clean up fine. I took mine on a bench grinder with a wire brush and carefully cleaned the ends then sprayed electric motor cleaner throughout. Good as new ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
It's an optical illusion and a later of dirt that makes it look like a huge crack. None the less, I'll find out about the block here in a few hours when I drop it off for cleaning up and boring.
![]() Quote:
Welp, took the engine in last night to get it all checked out and rebored, valves grounded down, valve sets relapped and cleaned. I can't wait to see how it looks when I get it back. Sorry, no new pics as of right now. But next week I'll be spending the time taking apart the frame.......which leads me to my next question....those of you who have done a frame up restoration or even just a new paint job. What are you doing for surface prep and just how much work should I be doing? My goal is to have it look it did when my dad brought it home. Are you taking it down all the way to bare metal? or just cleaning the current paint and sanding it down?
Thanks, and I'll post pics of the machine work when I get it back.
