Old 07-07-2014, 02:20 PM
I think I had more coffee than you........
Apparently.... LOL
I guess we're even now.
Old 07-07-2014, 04:39 PM
dbuck dbuck is offline
Smile
The correct terminal to check to see of the solenoid coil is good, is the "S" terminal to ground.
I mis-typed the I, should have been S. If I understand you correctly, run a jumper from the S terminal to ground?
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 07-07-2014, 04:44 PM
Smile
Here is a typical Starter Solenoid Schematic.......
My solenoid has a 4th post, which is ground.
Old 07-07-2014, 04:47 PM
NOPE....
Jumper Wire from the Battery + terminal to the Solenoid "S" terminal. Does the solenoid energize..???
Old 07-07-2014, 05:04 PM
It could be, but that's usually only on relay's. If it is marked with an "I", then no that is for Ignition. It's a terminal that was used to keep power going to the ignition circuit during cranking.
Old 07-07-2014, 10:25 PM
I think he mis typed the I. If it's a four post then the coil of the solenoid is grounded out through that fourth post instead of grounding through the case of it like a 3 post. The 4th post needs to have a wire from it to the case or ground. You have 2 small posts and 2 large posts correct? A 4 post will never work unless the additional ground wire is ran from the extra post on the coil to ground.
Old 07-07-2014, 11:14 PM
There are two types of four post solenoids. One style the forth is a ground, the other style it is an ignition terminal. It is unlikely if it is marked "I" that it is a ground. "I" is for ignition. I'm quite sure on this. As a matter of fact, I installed one today. The "I" terminal did not need to be grounded.
Old 07-08-2014, 12:03 AM
This could be all cleared up if we have some pictures.
What we do know, the solenoid is NOT OEM.
Old 07-09-2014, 07:00 AM
Smile
I have a camera, but have not fiqured out how to post pictures. True it is not OEM.
Old 07-09-2014, 07:13 AM
This was posted in 2009......... Attaching Images
