Old 07-07-2014, 06:47 AM
Attached, is a Colored Coded PTO Circuit Diagram...
Old 07-07-2014, 08:04 AM
Originally Posted by tex599 View Post
Went to mow yesterday with my 1989 1050 and noticed the PTO clutch would not disengage unless I turned the key off. When flipping the PTO switch it does nothing so it is always engaged.
Pull the wire going to it, if that kills it you have a electrical short if not the bearing is locked up on it.
Bearing. When you restart the engine, do the blades turn on the mower with the PTO switch off?
Old 07-07-2014, 08:10 AM
mickb72 mickb72 is offline
Default cub
I believe the reverse relay has been removed from the equation, but I can check. Where is it located?
Hello, i think the reverse relay on a 1050 is next to the shifter. Take off the center cover. Mike
Old 07-07-2014, 08:37 AM
No it isn't. That is the reverse switch. Relay is where I stated it is.
Old 07-07-2014, 10:15 AM
tex599 tex599 is offline
Mike, the blades only spin when the PTO is engaged. The bearing is not locked up. The relay for the PTO is located on the left side on of the instrument panel down low. There is another relay under the gear box cover, I take it this is the reverse lockout, how does that play into the PTO engagement. I could always mow in reverse. How do I eliminate the relay to test the PTO switch or vice versa? Each part is $50, but would rather buy only what I need. Thanks for the help
Old 07-07-2014, 10:35 AM
Looking at the diagram Roland sent, there are multiple relays involved. Looking at the parts diagram, what does this relay control 925-0894? This is the one that is attached on the left side of the instrument pedestal.
Thanks, Scott
Old 07-07-2014, 11:20 AM
There is only ONE relay (reverse relay) and two safety switches (Seat SW & Reverse SW), and obviously the PTO engagement SW, in the PTO Circuit
Old 07-07-2014, 12:34 PM
Yes.
If you have a wiring diagram, then trace the circuit. You should be able to see how it works. If you don't understand the diagram, then someone will explain it.
You don't really eliminate them to test, you use a test light or a meter to see if each component is working. Do you own either?
As Roland said. No, there is only one. The rest are switches.
You have been given a diagram. You said you have been looking in the parts book. If you read the part descriptions, you will see the name of the parts. It should be obvious by description that there is only one relay in the circuit. Like I said, read through it, it's a pretty basic relay circuit. If you still don't understand, then I or someone will explain.
Old 07-08-2014, 01:30 PM
Thanks guys, I think the problem was with the reverse switch. The connection was corroded a good cleaning and it seems to be working. Now my belt snapped, so I have to get a new one before I really test it out.
