Yes, I set the valves per the manual I printed from this forum and my 321 runs real nice. I wonder if the coil isn't burnt up, but first I'm thinking timing/valves like everyone else. Print the manual and find an easy chair, lot of good info there, including some troubleshooting.
Philip 1450, 1015, and a pile of parts. |
your video is private
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
I guess until we all understand what this "chugg" is, we all might as well CHUGG another BEER!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
HEAR HEAR to the beer!!!! How about something simple like the spark plug? I have seen a cracked plug wreak alot of havoc and cause people to do reeeaaallllyyy bad things to their tractors/cars. Just my thoughts.
one thing you mentioned that the condenser wire was broken. usually this leads to burnt points. I don't know what you check? but I'd replace them.
check the compression release on the cam .that will let the engine turn over real slow if it is not right or working. i had a 125 to do the same thing and that is what it was.
check your compression release. they give you specs in the manual on how to adjust it
I adjusted the timing. Lined up the S on the flywheel and set the valves - intake .010, exhaust .018. & set the points .020. I tried starting it again. shaft turned normally [better then it has] ...for about 2 sec' then started dragging again. Starter motor got real hot.
I think the starter is over heating and perhaps causing some of the issue. So timing is presumably good (as far as I can tell) I put a new regulator on. Also the solenoid ( I think) started humming after a I tried starting it a couple times it comes and goes. You think perhaps it got damaged with all the messing around. What do you think about the starter getting hot? I put a Volt meter on it and seemed like a lot of power loss. I think we're heading in the right direction. ![]()
