Old 05-23-2014, 05:13 PM
Thanks J-Mech, I appreciate that. I did see some flex material for sale at some places. I need to determine the true thickness of the flex material first. Still wondering if anyone has done the "fix". (yea, they have replaced it) Thanks, TB
Old 05-23-2014, 06:13 PM
dale c. dale c. is offline
I've used the standard 3 pin driver on a few now .I knock out the hub with the solid bushing in it and use a lathe to enlarge the hole to the right size to fit over the bushing hub with the swivel ball bushing in it then bolt it to the engine just like the flexible drive plate
Old 05-23-2014, 08:06 PM
Hmm great idea dale c. That is surely something to consider. Thanks! TB
Old 05-25-2014, 10:36 PM
Hand_108 Hand_108 is offline
Inactive Member
The quiet line 3 speeds had a 3 pin driver that would flex with the ISO bushings to keep the drive line from binding. I fixed that problem by installing solid engine mounts and using a standard 3 pin driver on my nephew's 1200.
I did the same thing with my 1200. Added solid motor mounts and a 3 pin driver and was set!!! Works great and cost WAY less than that stupid flex disk.
John
