Old 05-19-2014, 10:24 PM
Berwil's Avatar
Berwil Berwil is offline
Originally Posted by kostendorf View Post
My 1650 too has this shutoff. I have not worried about shutting it off for two years with no ill effects.
I park it in the attached garage during the winter for snow removal. My wife walked in the there once and the carb needle did not seat and leaked all over. I now get asked every time I park it if the gas is off.
Bill
Old 05-20-2014, 07:36 AM
sawdustdad's Avatar
Originally Posted by Cubby guy View Post
My 800 has the push/pull type of cutoff, a 1976 model.
My 1000 has the push-pull fuel shut off too. Only QL I've seen with one. Well, of the 5 I've worked on.
And I've had the carb needle stick on my 108, and, over the winter, drain the fuel tank on to a shed floor.
Old 05-20-2014, 10:34 AM
Someone left the firewall out of mine many years ago (I think it may have come with the tractor in a box of parts) so I'm not sure it hits it. BUT... I did buy a "bubba'd up" side tin on ebay for $5 that someone popped a hole in for shut off access. No need to remove it now and no guilt about doing it to my tins!
Old 05-20-2014, 10:44 AM
Nitro's Avatar
Nitro Nitro is offline
Originally Posted by Maxwelhse View Post
I'm confused... You're using 3/8" line on a 1/4" nipple?
also.. I'm a a fuel filter nazi.. If it runs fuel and has a piston, I put a filter on it. If you end up with 1/4" line and change your mind I can probably attempt to take a picture of what I did on mine if you'd like to see it. It's nothing special.
It had 3/8 line, carb fitting, and shutoff when I bought it. A 1/4" filter will be much easier to find in an appropriate size.
Philip
1450, 1015, and a pile of parts.
Old 05-24-2014, 10:13 AM
Bob95065 Bob95065 is offline
My shut-off valve looks like the one on this tank:
Notice the red arm on the valve. It is a 90° close valve.
The picture came from this thread: http://www.onlycubcadets.net/forum/s...ad.php?t=32139
Old 05-24-2014, 12:12 PM
Nitro's Avatar
Bob, that is what mine had. I have a new thumbscrew type to install today. I liked it because it is difficult to reach with the sides on, but with a new carb I don't expect any needle/seat or float problems.
Philip
Old 05-25-2014, 09:41 AM
My valve is leaking. The valves I see are all the screw in type.
Old 05-25-2014, 09:56 AM
Nitro's Avatar
Yes, I couldn't find the lever type. I like the non-leaking style much better tho.
Philip
Old 05-25-2014, 09:59 AM
dbuck dbuck is offline
Smile
My CC149 like Maxwelhses has the thumb screw shut fuel shut off and I also have a fuel filter between the the tank outlet and the carb. inlet. I use a clear filter from NAPA.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 05-25-2014, 11:37 AM
bkw3614 bkw3614 is offline
My 1250 Nightmare has the 1/4 turn ball valve on its fuel tank.
I took a heavy wire coat hanger, cut out a piece of the hanger and bent a v in one end to turn on the fuel, and bent a hook on the other end to turn off the valve. A magnet holds the tool to the tunnel cover. I never have to loosen the thumbscrew for the side cover.
