Old 02-21-2010, 09:57 PM
mrjeep81's Avatar
mrjeep81 mrjeep81 is offline
If you can tell me where to get the tines, that would be a great start. I have the steel and equipment to build one.
Old 02-21-2010, 10:54 PM
ihnick's Avatar
ihnick ihnick is offline
Idk how you would make the tines. My landscape rake is a factory cub cadet attachment.
Nick.
Old 03-04-2010, 11:11 PM
young enthusiest's Avatar
Hey, it's been a while, but I got new rings, and valve guides put in the engine. Put the motor back in tonight, no clutch, just to hear it run. It runs good. Got a wiring harness, and key comeing soon. A little work on the paint, put a plow behind it and I'm set for spring!
Old 03-05-2010, 12:33 PM
Forgot to mention that I'm going to add a pointszver system on this tractor too. Hopefully new loaded ag tires too. The steering on this tractor was in very good shape. Just needed a new cam follower, and one new tie rod end. It only has a little it of play in it now. The axle only walks a little, but I'm going to take the axle out, and tighten up the mount with a bolt, and see if it helps. Anything else anyone thinks I might need to do to this tractor to make it good again?
