Old 04-18-2014, 09:17 AM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
push the side wall down as far as you can and spray the bead with BP blaster do this a couple days then try breaking down again I did it and it work the blaster loosen the rust that had it stuck to the rim
Old 04-18-2014, 10:48 AM
IAMBEN IAMBEN is offline
Pull the valve stem core and lay it flat on the ground and put the edge of a loader bucket as close to the rim as you can and push down gently with the loader. Skid steers work awesome for this. You might ruin the tire no matter what you do when they are that old. Don't forget to apply dish soap to the bead when you are mounting or dismounting a tire!!! You would be amazed at how easily a tire slides on and off the rim with soap on the bead. A good set of spoons is a must as well.
Old 04-18-2014, 11:19 AM
If you're not saving your tire just cut them off.Worked for me.
