Old 04-09-2014, 04:47 PM
kostendorf's Avatar
I've been retired since aug. 2006 and I'm still looking for free time!!! I really think I got more done when I was working.
Old 04-09-2014, 06:18 PM
Man do I know that feeling.
Old 05-01-2014, 09:48 PM
Well, a rainy week means I have time to tinker with the shredder. I gave up quickly on the idea of finding the "correct" mounting brackets for this thing, and vetoed the idea of making them. I honestly think the front mount design is a poor design (and I will not say that my plans are any better). A PO that had this was working on making it run from the back. I am going to try and adapt this design to my 72 (anyone who has tuned into my posts will see I finally might have a use for this 72!) Pics to come shortly.
Old 05-01-2014, 10:03 PM
I started off tonight by mounting this rear plate that came with the shredder. It bots to the three bolts that the hitch mounts to. I plan on running the chipper sideways on these mounts and bolting the chipper to the bracket with some angle iron brackets im building up.
Old 05-01-2014, 10:09 PM
My plans for the drive belt are similar to a tiller. Using one long belt off the
PTO, through a mule drive, and builing a set of idler pulleys inbetween the bracket channels to run the belt up to the shredder pulley. Then that way I can use the mule drive to tightem/loosen the belt. If this design dosnet work well I may split the belt in two with a exchange pulley in the center of the tractor. More pics here. I mounted the screen in tonight as well.
Old 05-01-2014, 10:26 PM
Berwil's Avatar
Berwil Berwil is offline
That will be neat on the back. Have you thought about trying to make it run off a rear pto? Finally have a cool use for one besides making ice cream. Which way does the chipper spin, may have to turn it around and drive it from the other side. I know the 72 doesn't have rear pto, but one of those machines in your sig does I'm sure! Regardless, cool project!
Bill
Old 05-01-2014, 10:30 PM
haha, you are right! I do have several rear PTO tractors around. I have thought about that, but I dont think I could get enough rpm's out of it...
Any constructive ideas or thoughts are welcomed!
Old 05-01-2014, 11:08 PM
Berwil's Avatar
There are a few of you guys that have all the fun toys! I thought the rear pto was the same as engine rpm, no? I don't know much about them, just they spin backwards.
Thats a pretty big pulley on the side of the chipper compared to the pto pulley so it should spin slower than engine speed......maybe the same as the rear pto. HaHa
Bill
Old 05-02-2014, 12:34 AM
Big pulley, little pulley. Change them to get the speed right. NBD.
Two things: 1.)That's a lot of weight to be hanging off of 3 3/8" bolts. Might want to make a brace.
2.)If your going to drive it off the rear and you don't use the rear PTO, why not just use a tiller gear box. That way you can use the same belt. Just unbolt the box and turn it 90°. The rear gearbox plate is made so you can do that. The holes are already there. (On the newer style, some of the old gearbox brackets didn't have both sets of holes.)
Bill
Rear PTO's on the gear drives run 540 RPM. The ones on the super's run faster...... 1800 I think, but I'd have to look.
Old 05-02-2014, 06:36 AM
Looking forward to your build Ryan! Definitely unique with the chipper mounted on the rear.
