![]() Quote:
And yes, I did have the headlight wire hooked to the G tab. I will clean up where it mounts with a wire bruch and see if I can get a decent ground without a wire. |
OK, I now have a good ground to the VR body with the engine running. Still nothing. I have disconnected the Gen and Field wires at both ends and checked for continuity. My Bat wire to the VR has 12v at all times. What next?
With all wires connected and the engine running what is the voltage on the "G" terminal of the VR? (Engine at about half throttle.)
It sounds like you have an issue concerning the v/r. Possible adjustment internally or normally closed tips are glazed or corroded. Read the service manual on how to check/adjust internal v/r tips.
![]() Quote:
Right now I get about 12.4v on the bat with the engine off and 12.9v with the engine running. That may be a bit low but it will hold me for a while till I get another VR. |
Right now I get about 12.4v on the bat with the engine off and 12.9v with the engine running. That may be a bit low but it will hold me for a while till I get another VR.[/QUOTE]
That still sounds a bit low (I'm thinking that the voltage for charging should be around 13.2-13.5.....someone that knows for sure will answer shortly). Corroded connections can be a real issue for these 30+year old tractors.
Only thing better than having a Cub Cadet is USING one ![]() ![]() |
12.9 at idle is ok. Unless that is at half throttle or more. It should be over 13 yes. Honestly, it should be around 14-14.4, but that's hard to get out of an old generator and wiring.
Put a new voltage regulator in today. Finally got it wired up right. Acted kinda funny at first but after I powered it up and down a couple of times, I now have 13v at half throttle and it is showing a charge at the meter. THanks guys for your help and patience.
