![]() Quote:
-Ryan
I have to say I agree with the working load but just with blades on my 1450 has went through almost three tanks this winter as my 1000 has only used one.
No more cubs. But never fear there will be more ![]() ![]() ![]() ![]() |
I noticed the same thing 1650/1812 with my 1650 moldboard plowing I could run 3-4 hours on a tank of fuel , upgraded to a 1812 and better check the fuel every hour or so, otherwise enjoy a long walk back to the truck.
![]() Quote:
2 more horse on the 18' and pulling the same plow ![]() ![]() |
![]() Quote:
What about walk behind mowers? I had two walk behinds, one with the Kawi motor and one with the kohler and the kohler would run through two tanks before the Kawasaki would run through one. Both mowers worked the same grounds and had the same drive system and mower deck size....? Do the kawasakis do better on fuel than other engines? The engine in my gator does work pretty hard...climbing hills with a load in the bed. The only real big load I've had on the cubs is mower decks. Which does work the engine way harder but still it gulps fuel. I prefer kohler in general as my engine of choice but for a walk behind or piece of commercial equipment I'll choose the Kawasaki for fuel efficiency. |
![]() Quote:
![]() Quote:
![]() You have a lot more variables than engine brand. |
![]() Quote:
It's very technical to make fuel consumption comparisons. SOOOOOO many variables. It truly can only be done in a controlled environment, such as on a dyno. |
![]() Quote:
Bill |
Get ya a 1650 and a 1250 run 50 inch decks on both. Same lot same height of grass both tuned perfectly. Only real thing is that 1250 is going to be working harder. Now take both and let em idle in the driveway that 1250 will prolly come out on top
