Old 02-03-2014, 09:18 AM
andyw's Avatar
andyw andyw is offline
Looks good Andy. How did the drive shaft work out vibration wise? Have you had a chance to run it around yet?
Nope not yet... just idling in the garage. But that alone was signifigantly better. Remember I am coming from a tore rag joint so anything is better than that vibration. lol
1772 undergoing some updating.
Old 02-07-2014, 12:52 PM
CTRUEX CTRUEX is offline
Looks great Andy! Two things: why a 1/2" belt, and now that you have 40 amps, check out these lights, or Harley-Davidson 4-1/2" halogen spotlights (H3 bulb). I like eBay too.
Old 02-08-2014, 11:43 AM
andyw's Avatar
honestly, it was a matter of ignorance. I was impatient and did not get the correct width apparently, I see now this same belt comes in a .44 width which will set down in the grove much better. Thanks for that catch. Now that I know its all good and fit well I will probably order the correct width belt.
Nice find on those headlights. I may just do that, those will help me find the grill from it. I evidently fell off while mowing way out back in the fall The kids and I will go on a treasure hunt back there and hope for the best once all this dastardly snow melts.
And Sam, all is great on vibration. I blew snow after this last storm and it was smoother than its been in years. Did my drive and two of my neighbors... got a lil carried away, no harm done. lol
Old 02-13-2014, 10:23 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Wow I wish I had known about this different alternator before dropping $250ish on a stock setup...
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 02-14-2014, 07:52 AM
MWShaw's Avatar
MWShaw MWShaw is offline
Nice work on the upgrades.
Old 06-13-2014, 07:32 AM
sbauerz28's Avatar
Andy
I have a 1572 and I'm going to buy the 40a Kubota alternator for it soon. I just have 1 question about the wiring. There are 2 flat blade terminals on the back of the alternator. The one you connected to the yellow wire. I think this is key on power that the alternator uses as a voltage sensing wire. What wire if any did you hook to the other terminal on the alternator?
