Old 02-02-2014, 12:34 AM
Great job on the repair, Sam!
Old 02-02-2014, 06:31 AM
Mike
Cocktail hour is the best part of the day.
I agree!
Old 02-02-2014, 07:43 AM
I am not a welder by ANY stretch of the imagination ( or is it hallucination?? ) so I won't criticize that much, other than to say it was a poor job.
You are right...some people should not be allowed near tools.
My late dad worked for IH for 31 years, so oldest brother & I have pretty good mechanical/technical skills. Our middle brother, however, is not. Place him and a tool box in the same room and what you have is a train wreck in progress. He is a great photographer, while I can break those one-use 35MM film cameras before I take the second shot.
I do like the template you made to get things back together properly.
Let us know how it works.
Regards
Cubby Guy
Only thing better than having a Cub Cadet is USING one
Old 02-03-2014, 05:29 PM
I got the reinforcement plate made and welded onto the idler plate today. 1/4" thick X 4" steel bent to fit with four 1/2" bolt holes. Something more important will break before this.
Old 02-03-2014, 10:06 PM
Thanks for the update and pics, Sam!
Old 02-04-2014, 06:13 AM
Looks good Sam! You got that right!
Old 02-04-2014, 07:06 AM
I'll weld the underside when I pull the mount off to sand blast it. The deck shell has a couple small cracks that also need a little touch up and some reinforcements.
Old 02-04-2014, 07:23 AM
Leadslingingdaddy's Avatar
I'm glad somebody is getting work done....All I get to do is plow snow!!
Old 02-05-2014, 03:02 PM
Nice weather today so I got the wheels all cleaned up and the casters checked. At least the PO had a grease gun and used it. Also built up some of the worn areas on the lift linkage with the welder. Not much more I can do until I turn the water back on at the shop, then it will be sand blast, paint and reassemble time. Didn't bother with pics today.
Old 02-05-2014, 03:07 PM
Appreciate the update, Sam.
