I was thinking that also, Roland.
Thank you Guys.
Today, i worked at my Motor, after i started it, it runs perfectly, after few Seconds, the 782 began to shake and run not perfectly. I pulled the Sparks, and checked them, both are working, but the left one had a better Fire as the right one. As next, i installed the Spark Plugs in the Motor and started him, if i disconnect the left Wire, the Motor stops, and if i disconnect the right one, the Motor runs on one Cylinder. The same how few days ago. After this, i changed the Connections Sides at the Coil. The Problem was the same, but at the other Side, so i think it's a Problem of the Ignition. Tomorrow i will replace the Sparks and Wires with new ones, i hope the Coil is not damaged, tomorrow, i will know more, mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!! |
Georg,
I had a similar issue on a friend's tractor. It turned out to be the "metal cap" on the end of the spark plug wire was rusted and not making good contact. You may want to check. See: http://www.onlycubcadets.net/forum/s...ad.php?t=27905
I encountered that very problem and it turned out to be a bad coil. I hope it is something less expensive,as they are not cheap.
Good Luck! |
