Old 12-29-2013, 11:35 PM
macman81's Avatar
macman81 macman81 is offline
does anyone know for sure if a kohler command stator is the same mount pattern and diameter as a k341?
might have to find out.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 12-29-2013, 11:48 PM
Merk Merk is offline
I have an off topic tractor that has a snow thrower and soft sided cab. I've spent several hours in it with no heater. I usually unzip my coat when I run the tractor with cab. You get the inside of the cab too warm and snow will turn to ice when it hits the wind shield.
Had that problem with big tractors/trucks.
Project Uncle Dick
Cub Cadet 70
Old 12-30-2013, 10:11 AM
I think I would just mount a large battery on the back and run the heater from it. Put it on a battery charger when it's not in use. It would also give you more weight on the back.
Old 12-30-2013, 11:30 AM
Or, option 3... man up! Take the cab off and wear layers. My snow fighter never has a problem with foggy cabs.
Old 12-30-2013, 11:36 AM
OldSkull's Avatar
OldSkull OldSkull is offline
I'm in the same boat! I got the same idea, finding a 20 or 25A stator and regulator upgrade I could fit, now I wonder if we can rewire the original one in a way to produce more power.
For the moment the only cheap solution I found is using this ammo box to store a bigger deep cycle AGM battery in the back of the tractor.
Since you take more "Juice" then what the stator can provide, you need to plug the battery on a charger/maintainer after every use.
I wish someone come with a better idea
Gilles.
1963 100 (red)/in storage
Old 12-30-2013, 11:59 AM
Berwil's Avatar
Berwil Berwil is offline
What about adding an oil heat? Plumb two lines from the oil pan, drain plug for "suction", another or maybe new port for return. Put a little radiator, maybe a vehicle heater core at the base of the windshield with a fan behind it. Then you would only need to power a fan and small oil pump.
Someone else will probably chime in and remind me that there's only 2 quarts of oil in the engine and the last thing you want to do is take oil from the pan....but it's not the worst idea for a Monday before coffee. Haha
Otherwise I agree a second battery mounted on the back, plugged into a charger when not in use is what I would do.
Bill
Old 12-30-2013, 12:03 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Originally Posted by fourinchdragslicks View Post
the cab would pretty much only trap body heat. engine and exhaust heat is directed out the front of the tractor
Make you a replacement lower grill panel with a 4" flex dryer ducting with an inline fan. Run duct back to your cab.
Old 12-30-2013, 12:09 PM
OldSkull's Avatar
Hey it's not a bad idea bill! You give me another one
How about plumbing some copper line around the muffler and use Anti freeze instead of oil? A thermal switch can be use to start the fan and a thermostat on the radiator! This is a dam good coffee
Gilles.
Old 12-30-2013, 12:10 PM
Calvins66Cub's Avatar
If you wanted to run everything plus:
http://www.summitracing.com/parts/aa...0500/overview/
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 12-30-2013, 12:15 PM
macman81's Avatar
Any idea where to mount it? Lol
John,
PROUD OWNER
