Gotcha. I did not realize that the bearing had a shoulder. And then just a piece of plastic as a spacer? Do you have a part number for the bearings?
It used the plastic "bushing" originally, the bearing can be used as an "upgrade", either will work. If the steering tube is worn at all either may work it's way out, you can add washers as spacers under the steering wheel to help keep it in place.
Good luck,
David |
TIP:
If the bearing is sloppy in the tube, use a few 3,4 whatever it takes, small pieces of tin, sheet metal, Coffee can, whatever. Cut 'em about 1/4"or 3/8" X 1" or so and bend one end over about 1/4". Place these around the inside of the tube and cram the bearing in so it is tight. I have had to do this with several Cub front wheels in order to get the bearing tight in the hub. |
![]() Quote:
A. Use a center punch and put 3 or 4 dimples spaced evenly around the ouside of the tube about 3/16 down from the end. The raised tip of the dimple on the inside will grip the bearing. B. Apply a SMALL amount of JB Weld or a similar adhesive to the inside of the tube before you slide the bearing in. |
First of all thanks for all that have replied. I just want to clarify a couple of things.
Was the original "bearing" shown in the parts breakdoen just a plastic bushing that fit inside the column shaft and extended to the steering wheel? Or was there an actual bearing plus the plastic spacer as Lew has shown? I like the bearing idea if it fits correctly but if not I would just like to go stock to keep things clean without hacking the thing up too much. |
here is a picture of what belongs in your steering column.The foam bushing holds the plastic one in place.
I like the looks of the wheel bearing. Seems like alot better solution long term. The one that you showed in your previous both looked pretty snug. Is that what you have found with doing the wheel bearing?
Mine fit snug,but I did the dimple thing just in case.
I was surprised by the parts IH Cub Cadet I had pulled from the scrap recycler a few summers ago. The Ross steering unit was in good shape, aside from needing a typical rebuild. Someone had machined a brass bushing, similar to what is found in the front wheels of the original IH Cub Cadet, in place of the wheel bearing we're discussing here. The bushing was drilled and tapped, the outside shaft tube assembly drilled too, and a 90* grease fitting is in the hole.
I thought I had pictures somewhere about it, but like everything else at the moment,..... . The wheel bearing the group is discussing sounds like a winner! Good luck!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
hattrick 4467, when I rebuilt my steering column , the wheel bearing used up top was sloppy, so I wrapped a few pieces of aluminum duct tape around the bearing until it fit snug. Works great.
Chris
1968 104 , service replacement '96 K301, 42" deck 1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck 2007 LA130,21hp Intek v-twin, 48" deck ![]() ![]() |
