Old 12-19-2013, 05:40 PM
Originally Posted by tomr80 View Post
Where is the governor and how do I "clean it"? what is the correct gap for plugs? Autolite huh? What size you runnin? I replaced the original carb that was on the trator with a high/low adjustable one. The original was a piece of crap an old timer said, it did work a lot better but in the last 2 years id say this is what shes done. I run NGK plugs right now. Thanks
You can't "clean" a governor, and outside of the external linkage and adjustment, they are internal. If the carb is only a few years old, I'd say pull and clean it, drain and clean the fuel tank, new fuel lines, and filter. Make sure the fuel pump works. Then readjust your carb, and check or replace the ignition components. Spark plugs, wires, points and condenser. Kohler and CC called for Champion spark plugs. That's what I recommend and do run. As far as I am concerned, Autolite plugs are only good for a Ford, and even then they suck.
Old 12-20-2013, 07:22 AM
tomr80 tomr80 is offline
thanks guys! i put new wires on last year and condenser. i need to pickup new points, guess ill toss the ngk's and grab some champions. i'll have to clean that carb to. i noticed it had a turbolizer installed the last time i was in there. On a different note, ive ben looking for a 54" snowblade. I dont need the whole thing(springs, pivot cage, mule, etc) just the blade. anybody know whichway to point me?
Old 12-20-2013, 07:31 AM
I have had just the opposite experience when it comes to plugs, just my 2 cents but I'll stick to Autolite's, NGK's or Bosch.
Old 12-20-2013, 08:14 AM
cubs-n-bxrs's Avatar
X2 SamMac on the plugs. Friends don't let friends use champion plugs. LOL
In my 55+ years or so of wrenchin', spark plugs spark, if they didn't they wouldn't be in business.
Choose Blonde Brunett or Readhead.
On the points, 99% of the time a little swipe of fine emery or crocus cloth, and adjust properly, and they are fine.
Back when we had points in auto/trucks, ya after 50,000 miles they do get worn a bit but not on these little engines.
Do spend your $$ on air filters & good oil.
A good Gas filter keeps little things out of the carb.
And fresh fuel is good, do not use preminum, the Compression ratio does not require it.
And preminum is just not fresh, with 99.99% of people buying regular,
Preminum just sits in the underground tank.
Old 12-20-2013, 12:35 PM
LOL guys! I admit, when it comes down to spark plugs, it doesn't really matter. Like ol'George said..... spark plugs spark! I digress.
Old 12-22-2013, 09:58 AM
Think ill just get a points saver system, new plugs and points see what that does I guess!
