Old 12-06-2013, 02:51 PM
sawdustdad's Avatar
Didn't they switch the hydraulic lift actuator from the right to the left side of the dash tower? Mine are all on the right, even though a couple of mine have 1 inch front axle spindles and the wire loom through a firewall grommet with the PTO lead running up the right side. (both later changes). My 1450 project ("Frank-n-Tractor thread) has 3/4 inch front spindles and the PTO lead on the left side, so it must be an earlier version. It would be interesting to track the changes they made in chronological order over the production run of the QL tractors.
Old 12-06-2013, 04:51 PM
IH Cub Cadet IH Cub Cadet is offline
Great info - thanks everyone!!!!!!!!!!!!
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 12-06-2013, 05:42 PM
red56turbo's Avatar
The hydraulic lift handle always came from the factory on the right hand side. A lot of guys/gals have moved 'em to the left side. Makes more sense because of the F/R handle being on the right. Not too many people have two right hands. If I still had a quietline or two, I'd move my hydraulic lift levers all to the left.
Josh
Diesel Cub Cadets...........
Old 08-24-2014, 08:29 PM
johncub7172's Avatar
Some of the aluminum oil pans were different, and some of the engines had balance gears too.
+1 on different wire looms.
+1 on the duel Flex Disc Couplers.
Old 08-24-2014, 09:12 PM
john hall's Avatar
What models had internal wet brakes? I thought they all had external disc brakes (I'm thinking some of the NF early Cadets didn't but that's not the models being discussed). Was this something IH went to and then returned to external disc brakes on later models? I know my 982 has them, can't remember about the 2072.
Old 08-24-2014, 10:09 PM
kostendorf's Avatar
My 1650 cub cadet was made June 1977
Late - Aluminum grill I changed it to cast iron.
Early - 3/4" spindles
Late - internal wet brakes
Late - similar to 82 series tractor
Early, cast iron axle housings
Late - the loom going through a grommet in the fire wall and the PTO wire included in this bunch and going across the side of the engine to the right front to the PTO
Late - has large fuel cap
early - grounds to the rear right side 3/8" nose bolt
Aluminum oil pan. I changed to cast iron.
never had balance gears.
Like a lot of people out there I have no idea what mine came with originaly.
Jeff Baker from another forum started making this list.
I am making this list from info on the forum and found in my book.
If any are wrong please correct them..
Also add to the list if you have info
Cub cadet O
#501 thru 65457
a. mass production starts at 590
b. @ 10332 front spindle change from collars to 7/16 bolts
70/100
#65458 thru 127160
a. @ 70830 battery was changed to increase amprage capacity
71/1x2,3
#127161 thru 218009
a. first 123 is built #157490
b. ACR is introduced
72/1x4,5
#218010 thru 306085
73/1x6,7
#306086 thru 400000
a. 1st 147 is built #316816
b. yellow paint is changed @335968
c. white paint is changed @375939
86/1x8,9
#400001 thru 529999
a. hydro control handle coiled spring pin changed @428098
b. spark plug location changed @438962
c. PTO safety switch added @441194
d. Brake style PTO @482000
e. serial# 500000 is a 149
f. linkage on hydro is changed @503725
g. 1st 169 is built @506737
QL series
530000 thru 665000
a. steering tube change @530858
b. fuel tank change @560212
c. yellow paint change @562954
d. springs to screws on grill @565131
e. manual to auto relief valves 1450,1650 @590522
f. manual to auto relief valves 1250 @597245
g. muffler change @606613
h. grill screen change @613253
i. drive shaftchange @622957
j. front spindle size change @632502
k. wet brakes are introduced on GD @568544
l. wet brakes on hydros @604164
m. maintenance minder meter was changed @588841
82 series
665001 thru 700000
a.grill change @689330
b. final drive change @691605
By jeff l baker (Jbaker) on Saturday, April 06, 2013 - 10:55 pm:
Old 08-24-2014, 10:41 PM
All of this is great info, I'm also learning that I have to redo some things based on what I've learned, ugh. Excellent details though, thanks to all for posting
