Mine I think is 6 amps at full load. Its hooked to the standard cub set up for power with a Dpdt reversing switch.
Cub 104 Refurbed Sprinig of 2013 Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs |
I haven't looked that deep into the wiring diagram for my 108. When you say standard power area you saying there is an aux power setup or something else?
Nope. Hooked to the battery. No modifications to the battery or charging system to run it
![]() Quote:
Not sure of the exact model I'd have to go take it off the tractor to see the serial number/model number. Its a 1000lb 4" stroke linear actuator. Anything 500-1000 lb and 4-6" stroke will work.
Some good stuff here I think.
http://www.surpluscenter.com/shop.ax...words=Actuator |
I put a narrowframe hydro on my 147. It's not a simple bolt on by any means. Unless your mechanically inclined and have a good shop, I'd go with another option.
Thank you all for taking the time to answer my post. Not sure what I will be doing, but I know the white stuff will be on the ground soon enough.
![]() Quote:
My son built me a box scraper that weighs 175 lbs and it takes the both of us just to lift it off the ground using the existing lift lever! Dan |
I like the elift but the worst thing is fixing them when they break. I put new bearings, bushing, brushes in the motor on mine then the spiroid gear went. I haven't fixed it yet as I'm contemplating selling it and putting a winch on the tractor to raise and lower implements.
Curt |
