Closed Thread
Old 11-25-2013, 07:04 PM
Hopefully your input shaft did not damage the gear reduction housing ,I had one that did...
Old 11-25-2013, 07:49 PM
dodger9714 dodger9714 is offline
how much does the bearing cost??
Old 11-25-2013, 08:03 PM
Go to partstree.com, or cub cadet's website. Put in your model number, go to the "transmission case/diffirential/reduction housing" section and you can get a price.
After you do that..... you'll probably want a price from a bearing company.
Old 11-25-2013, 08:04 PM
sgirdham's Avatar
sgirdham sgirdham is offline
Like Sam said, take a look at the manuals, find the part number and do a search.
1981 IH Built 782- 44" deck
1650 dual stick
71 "121" round fender and replacement k301 carlisle tru powers and v61
Old 11-25-2013, 10:15 PM
austin8214's Avatar
The bearing is under $10
Old 11-26-2013, 01:14 AM
You sure you aren't looking at the ball bearing.....
I think that needle bearing would be more than that.
Old 11-26-2013, 02:09 PM
its the rear bearing ,what im asking, is will that make the tractor not work right??
Old 11-26-2013, 03:31 PM
Oh for crying out loud. A bearing out would make a lot of the driveline not right! Replace the bearing before you do anything else. What on earth do you want to know? Yes, a bearing out will make the driveline shake and shimmy. It will make the reduction housing gears not mesh and it WILL TEAR UP THE TEETH on the gear. REPLACE IT NOW! If the vibration doesn't go away..... come back and ask questions.
Old 11-26-2013, 04:33 PM
no need to be a jerk about it, but thanks for the answer and i will come back with what i get.
Old 11-26-2013, 04:59 PM
clint clint is offline
J-Mech attitudes like your post here don't help anyone with lack of confidence trying to find information, instructions etc ? Caps is considered screaming why would you "talk" to someone with 18 total post asking for help like that ? dodger9714 I apologize for J-Mech, and just hang around plenty of help/information offered on this site !!
1440
1282
1604 cast rear/transmission (582)
149
1450 (2)
JD317 54" blade
JD318
Ford 3600
Closed Thread
