Thread Tools
Display Modes
Here are a few pics. I was going to do a little work tonite, but a crappy day at work and that normally needs to unnecessary frustration and mistakes.
UPS guy was good to me! ![]() Bearing Plate ![]() ![]() Naked! ![]() ![]() Journals ![]() Hopefully a better mental state later this week and I'll get the old seal off, get everything assembly clean and get her buttoned back up. In the last pic, is that spring around the crank an inner part of the seal that I need to remove before reassembly? Any thoughts on some assembly lube on the main bearing for startup?
Kubota B7100 HST 4x4 w/FEL, 4' Bush Hog, Woods RM400 Finish Mower Original Member #54 |
Yes that spring was part of the old seal and needs to come off.
I just oiled up the bearing before I slipped it back on. One thing you can do is disconnect the coil and turn it over for about 10 seconds and this will return the oil to the journal and bearing, it's not a new bearing so I would not worry about bearing lube. A smear of 90 wt won't hurt either. It's your choice but I did not trust the little O-ring on the gasket, I used a very light film of #2 on the entire gasket. Scott |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Was checking my 982 over tonight before closing up the garage....can't wait to get out and work on it when the warmer weather comes in a couple months. If anything like last year it will be the nicest weather in April than it will be all summer. Think me and the boss will have to chat about holidays! ![]() :biggrin2.gif: |
I got some time to get my Onan back together. This morning I popped out the old seal, cleaned up the bearing surfaces for the gasket and put it back together. I used some permatex gasket sealer and let it sit (assembled) for a few hours. Finished throwing snow with my other tractor and decided to fire up the 982. Well, much to my dismay, it's leaking worse now from the same spot.
I ordered another bearing plate gasket and installed it with Permatex #2 instead of #3 like I used the first time
Gave all the tractors a wash today. I like the 982, but I wanted to get a tiller and blower for it and sell my JD that has those attachments. I guess the only tiller is shaft driven off the rear PTO, which I understand both are hard to come by and relatively expensive.
Awesome 982! I want one so bad. Even more now after getting the 682.
Jay N. Eau Claire, WI RED 82 Series... The BEST cure for Yellow fever! ![]() |
Glad it worked out for ya.
![]() Scott |
Really looks sharp!
Bob |
That's a great looking 982, toyman!
