Old 11-07-2013, 06:07 PM
Petrus's Avatar
Petrus Petrus is offline
I found out that it doesn't start right now because it's been sitting all summer not getting used so I'm going to bring a basic first aid kit to get it going.
Another angle would be to leave the burden of making it start on them. Since you talked them down to $500 on the basis that they said that it runs, the failure to start might help you knock off another $50 or more. It's up to your judgement and whether you are scared that the engine really is completely shot, I am just sitting here thinking of ideas and hoping that you get a good deal.
Old 11-08-2013, 10:02 AM
jimbob200521's Avatar
Darn you guys, you convinced me to get it! Here she is, coming off the truck. After 1 1/2 hours of a failed attempt trying to get it started, we found a ditch and pushed it on the truck. I will say, cosmetically, she is in really, really good shape. Most of the stuff in the pics is grease or dirt and should wash right off. Next pic is of the ol' girl in her new home surrounded by family I was impressed with how good of shape that hood emblem is, btw. Next is a better pic of the gearbox and rear lift, which I'm more excited about having than the tractor. Finally got one!! And then a quick pic of the tiller
Now for the good and bad news. Good news: Since we couldn't get it started and they've been "trying" to get rid of it for a while (they never advertised it, really), I asked if it'd be worth $400 to have the space back in the yard expecting a $450 counter but she took it! That's the good.
The bad: I couldn't get it started. I was able to confirm spark, but not 100% confirm fuel. I'm going to replace the fuel line on it this weekend, drain and put fresh fuel in it, and order a carb rebuild kit this morning along with a new spark plus wire (the old one is in rough shape for some reason). And finally, and I'm hoping it's just a loose wire or burnt out fuse, towards the end, the key would not make it crank anymore. As this is my first experience with a Quietline, I'm going to have to learn as I got but I do know the starter is good; I used a pair of jumper cables to "short" it to make sure it was still good and it turned the engine over.
So, that's my latest endeavor. This also means I have to find a new home for the 129 so if y'all want it, let me know! Too bad I couldn't convince the g/f to let me keep them all but I suppose she's right, she at least should be able to park her car in the garage over the coming winter
-Ryan
Old 11-08-2013, 11:27 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
I have the same set up! youll like it, congratz!
1- 1200 in pieces
1- 1864 in pieces
Old 11-08-2013, 12:16 PM
Congrats on getting it home!
Old 11-08-2013, 12:27 PM
Glad you got the 1450 and goodies!
Old 11-08-2013, 06:11 PM
782CC 782CC is offline
Once running it will be good to know if it is killing the motor instantly or dragging the motor down. Could be nothing more than the seat switch messed up.
Just a thought when checking out things like this. I use a ZEP sprayer to run engines when the carb is in question or need to start a very cold motor with shortage of choke. Or when a carb is empty. Washing down parts. I could go on. lol Very controllable.
http://www.grainger.com/Grainger/SUR...C&cm_vc=HPPVZ3
you will enjoy the tiller. I see it has belts. That is a big ticket item itself.
Old 11-08-2013, 06:16 PM
Never seen one of those before, looks very useful. And I'm curious to see that as well. I tried spinning the deck by hand and couldn't so I'm guessing it's the deck or mule drive both of which I have extras of. And yes, everything is there (save a few bolts) to hook the tiller up. I'm way too anxious to try it out next year, I've got a list already of work for it to do
-Ryan
Old 11-08-2013, 06:18 PM
Wait, seat switch? I thought they had one but I didn't see one when I looked Where am I looking for it?
-Ryan
Old 11-08-2013, 08:00 PM
Rescue11's Avatar
no seat switch on 1450. unless its aftermarket!
1- 1200 in pieces
1- 1864 in pieces
Old 11-08-2013, 10:12 PM
Wow! That 1450 is in excellent shape with extras! At $400, you made a really good deal and will be very happy with that cub when you start tilling. Just goes to show, great things come to those who are patient. Glad you made the score and it has found a good home.
