Old 10-30-2013, 09:07 AM
jimbob200521's Avatar
Check the fuel pump, I'd be willing to bet money that's where the fuel in the oil is coming from. Mine had the same problem when I bought it, so I found a Sten's replacement pump on Amazon and violla; good as new. $34.99 + S&H, can't beat that.
http://www.amazon.com/Fuel-Pump-KOHL...kt17+fuel+pump
Originally Posted by clint View Post
Nothing you can do other than keep oil level checked/topped off. No provision for a remote oil filter as it does not have pressurized lube system, series 1 uses splash lube. Lots of info on the series 1 vs series 2 by searching. As to value if it's a nice 782 it may be worth the asking price of $400. If I purchased it I would do so thinking it has a bad engine, look for a replacement engine a magnum 18, maybe one of the later v type engines B&S Vanguard etc. If you get the fuel pump replaced, and the engine runs then you have extra time to find an engine while using the 782.. Good luck
Somewhat true, somewhat false. When I got my 682 with a Series I, I did tons of looking up on them so I knew what I had gotten myself into. The Series I uses a pressurized spray lubrication, not splash. If operated on mostly level ground, these engines are just as reliable as the Series II's.
-Ryan
Old 10-30-2013, 10:34 AM
Same thing here. Fuel pump on my 1711 started filling the engine with gas. New pump, no more issues. To make things easier you will need to remove the tin on top of the motor. Not to difficult to do. Then you can get to the bolts that holds the fuel pump to the engine.
