Sam, you were right about the cups, the upper one was actually worn thru and the bottom one wasnt far behind.
I'm glad you recomended the cups, I almost didnt bother with them. Thanks again. |
Not sure why you guys don't believe me when I tell you that this ain't just another pretty face...
Seriously, glad to hear things are working out for you.
I finnaly got around to almost finishing my steering rebuild.
I reamed out the spindle to install a 3/8'" bronze bushing. The pitman arm seems to have no movement now. But I broke off the grease zerk on the axle, so now I have to get it out. It looks like it was a press in fitting because it did not have any "sides" on it to put a wrench to it. Am I right, and what size does it take??? |
You are lucky, On my 70 the PO had tac welded the nut on to the shaft. I had to cut the whole thing off and replace it. the zerk shouldn't be hard to replace I have drilled them out before, then just replace it. JMPO but I do love the Ross upgrade. Works well on both my 70 and a big difference on my 782. Glad you found the problem.
