Darrell,
The engine and the CCC 782 Hydro ran good before I started the switch, I just wanted to keep the red IH 782 brand. I did not switch the ignition switch but used the one that was in the IH built 782. That may be reason why the ignition switch will not start the tractor. I've had this problem on other 782's and I bypass ignition switch and install a push button starter switch and cables to the starter solenoid. This seems to work just fine to start tractor. I did check the voltage at battery with engine running and getting close to 14 volts which I though would be normal. I'm wondering if I might have something else wired wrong that is draining battery when it is not being used or if the battery is bad and does not hold charge (battery is new). Thanks for your help. Larry J-Mech. Thanks for the information on the PTO relay. I checked and the seat safety switch is connected to the relay. Thanks again. Larry
Cub Cadet's I have are (1) IH 782 for pulling Trailer, (1) CCC 1711 GT with 44" Mower (1) CCC 2284 SGT with 60" Mower and (1) CCC 1864 SGT with 50" Mower. Farm tractors I have are 1956 Ford 641 and 2005 John Deere 5320 with Loader. |
