Old 06-23-2013, 11:57 PM
Originally Posted by Shaner View Post
most people recommend NEVER putting a load on the tractor when the creeper is in LOW range. the creeper was only meant to slow ground speed to run a rototiller or a snow thrower. NOT meant to be plowed with.
ABSOLUTELY CORRECT!
We do not plow with the creeper in low range.
Old 06-24-2013, 12:09 AM
Ok. Got to ask. I've never heard that the creeper wouldn't handle a load.... I'm not wanting to start a debate here, but between the F-Cubs and the cadets, I've never until now heard not to use one under load. Being that it is before the reduction gears I wouldn't think if the creeper was in good working order it would hurt it at all.... Is this a personal opinion? Or a general consensus?
Old 06-24-2013, 09:13 AM
sawdustdad's Avatar
I'd like an answer to this as well. Seems it's a low torque situation given it's off the driveshaft--high speed, lower torque. Does that mean you can't pull stumps with the creeper? (not that it's needed...)
Old 06-24-2013, 09:33 AM
Humphrey Humphrey is offline
It is primary reduction, so it shouldn't hurt much of anything to use it. The teeth on the sun gear are either locked into the transfer gears for reduction or the input housing. The only real weak spot could be the pins that hold the planetary gears in place, but there is 3 of them so the load shouldn't be over bearing.
Old 06-24-2013, 01:06 PM
I don't have "authentic" documentation stating the particular uses/non uses of a creeper gear, although I feel confident that something along those lines does exist.
So I did a quick search and came up with a number of threads concerning this very topic, here is one that pretty much says it all, and to top it off, most of the posters are people that I have a great deal of respect for and whose opinion I trust very much.
http://www.onlycubcadets.net/forum/s...hlight=Creeper
And another...
http://www.onlycubcadets.net/forum/s...hlight=creeper
