Congrats on the 126.
Cool story ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
so i took the advice gave and opened up the top of the trans to see what gives with the shifter not working in first or reverse. turns out massive rust on the shaft that has to move forward/back to allow shifter to work. so half a can of penetrating oil and some creative tapping on a vise grip clamped to the shaft with a chisel and hammer, and its freed up and working good now. i didnt see any major problems other than the rust. the fork was bent a bit but i squeezed it back with the vise grip to match the other side.
should be ready to rock and roll when the storm clears in three days. i drained the rear end and need to know what fluid you guys use in them. looks like vanilla milkshake with all the water in there but smells like old 80w90. whats the correct fluid to use?? anyone know where to get a throwout bearing thats not 30+ dollars? would a front wheel bearing with a 5/8 id work or would it not be strong enough for the application? thanks for the advice and support guys. cant wait to get this puppy up and running to its full potential. unfortunately i have too many cubs so if anyone can help me find a new home for it that would be great. ill list it for sale but not till i get everything working again.
John, PROUD OWNER ![]() ![]() ![]() |
The Fluid in it was most Likely IH Hy-Tran... it is still available at your local Case/IH dealer as well as CC dealers. Some people swear by it, I have been using stuff from my local hardware/farm store, and it seems to be working just fine. It says it has the same "water encapsulation" properties as the Hy-Tran for about half the price.
- Cory Sanderson -~~- Cub Cadet 104 -~~- Cub Cadet 104 -~~- Cub Original -~~- Cub Lo-Boy 154 -~~- |
![]() Quote:
$30 is pretty much as cheap as you'll find for a throw out bearing.
Web Developer - Need a website? Contact me. |
![]() Quote:
Lets not turn this into a for sale listing. If it's for sale it will be in the for sale section until then it's not for sale.
No problem. Where in WI did you find it? Looks like a fun project.
Wow, that's pretty rusty in there. Glad you got it all cleaned up and working well!
Whatever water/oil mix was in my original transmission had a heavyweight oil smell to it, and was THICK! Had to clean out a lot of the gunky mess with paper towels.
Russell Cub Cadet Original w/ 3pt Cub Cadet Original w/ fenders, creeper, & 3pt Cub 100 w/ 3pt Cub 125 w/ 3pt NF Blade, cultivator, brinly plow, 38" & 42" deck, disc, tiller |
Sounds exactly like mine! Think ill put hy-tran in it since that's what most people are using.
