Old 04-24-2013, 10:09 AM
bullockcm bullockcm is offline
Originally Posted by TheSaturnV View Post
Sounds like your key switch bullockcm. I've bought around 6 garden tractors of various makes, and every last one of them needed a new IGN switch.
I am not familier with garden tractor electrical systems so you may well be right but it would seem to me the IGN switch is fine in my case since when I turn the switch to the start position I can hear the solenoid click, it just doesn't appear to be powering the starter/generator at that point.
My guess was a faulty or improperly wired solenoid. I should add that the wiring is butchered pretty badly on the thing. I actually think someone had a pile of rough/misc. cub parts that they bolted together and I was dumb enough to buy it... On the other hand maybe the seemingly good running 12HP engine, 50" deck, and wheel weights are worth what I paid. If nothing else it will be something to learn on and nobody ever said education was free
Could you elaborate on why you think my IGN switch is at fault?
Old 04-24-2013, 04:18 PM
TheSaturnV's Avatar
I shouldn't be allowed onto the interwebs after a certain time. If your solenoid is clearly clicking, then check the following:
Clean battery terminals
Direct jump the s/g
Check the wiring from the solenoid forward
Old 04-24-2013, 06:13 PM
coony10 coony10 is offline
The ignition and solenoid was changed last year and it worked fine until this spring. I took the starter generator off and took it to have it checked. They rebuilt it and I'll let you guys know how it goes.
Old 06-04-2013, 12:42 PM
DaveBiz DaveBiz is offline
I had that problem on a LT1045 this spring. It was the terminals on the solenoid, the tractor had been left uncovered over the winter and they had rusted. Removed, cleaned up, re-assembled, and good to go. This might be your problem if you don't get power to the starter.
Old 06-04-2013, 02:25 PM
MBounds's Avatar
MBounds MBounds is offline
On that 129.,, IH tractors a of all kinds are notorious for having corroded ground cables at BOTH ends. Clean them and/or replace those Ground cables!!! The frame ends are always neglected!!! Check that ground strap to the engine block also.
Myron B
East Texas
Most of of the fleet:
Cub Cadets: 2 Orig,70,71,122,123,104,124,126,86,128, 109,800,1200,1250,1450,1650,IH 682,782D,IH 982. Cadets: 76,SO76,80,81,IH 182. RER: 60,75. Elec 95. Trailers: #2, #3, #4, 1200-A,1200-B,1200-C, 2000. IH 1210 P/U, an IH Scout II and an IH Scout 800 to tow 'em with.
