Not really interested in doing so. And to be honest unless your driver is a kid under #100 or so it really doesn't put the weight where you want it. You're much better off with under trans box or belly bar.
I am with Stacey on this one! We run a bracket underneath the trans and have 2 steel slabs about 25 pound each that "pinch" the angle to stay in place. you can loosen and slide back and forth. We are toying with adding another slab and removing some belly weight in hopes of getting the tractor to hook alittle harder. We run a higher tire speed but on a stocker that weight down low will help also, and will reduce the teater totter effect. I can make a rack for you if you are interested in this style set up but it is dependent on the hitch and wheelie bars you run. I can shoot you a few pictures on your phone or e-mail if you'd like me too
