How's that old saying go, If It Ain't Broke, Don't Fix It?
Keep dragg'n em in. They're like orphans...they all need a place to call home. |
What I've been doing to running engines is change oil, a head gasket replacement (and clean the combustion chamber/flatten the head if needed), new points, rebuild the PTO clutch, new clutch bearing, new condenser, plug, static time the engine, clean and repaint the engine and tins, clean breather assy, rebuild carb and re-assemble with new gaskets. I figure that's good for another 10 years of work.
That may be more than you need to do, but it's about everything that can be done short of pulling the flywheel, oil pan and engine internals. I don't replace oil seals unless they are are leaking. That would be one more task that you might consider, but you'll need to pull the starter pulley/clutch basket and the flywheel to do those.
Thanks fellas! Sawdust, thanks for a comprehensive list of recommendations. I'll probably do about that. Sounds like you guys don't recommend a lower overhaul if it is running well. Appreciate the input!
![]() Quote:
You might consider removing the balance gears, some consider those to be a ticking time-bomb in the Kohler 14.
NICE 147 btw, and great progress. |
I can't help but notice what good condition the hub caps and the electric lift are in. It is very rare to find a 147 in this condition. There is a big push in the classic car market right now for cars in original good condition. It is only original once. I vote clean it wax it and use it with care.
![]() You may already know it but the hub caps and electric lift may be worth more than you paid for the whole tractor!
![]() Quote:
PS what were the flanges on the rear of the frame? Never seen those before.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
where are you located, im in canandagiua.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10: ![]() |
![]() Quote:
Saturn V - would you be willing to elaborate? I need to learn more......
