Old 04-08-2013, 06:52 PM
MrGitrdone41's Avatar
I use a bench vice to get out the roll pin. 1.lightly clamp the drive shaft 2.tap on the end on the drive shaft on the clutch end. 3.tighten vice 4. tap out the roll pin. 5.slowly release the vice. That's the way I do it and it works great for me.
1988 1812,dual ports
1973 108
1968 125
Old 04-08-2013, 07:31 PM
dagenham dagenham is offline
Be careful, I've seen little things like this turn into full blown restorations.
Old 04-08-2013, 08:08 PM
CadetTY's Avatar
CadetTY CadetTY is offline
Yeah i was just thinkin last night i should keep going and repaint bt i need it to plow some dirt so shes goin back together lol
882 diesel, x3 ih 582, 73 124, x2 82 seriers pullers, 1686 16hp puller
Old 04-08-2013, 09:43 PM
sawdustdad's Avatar
I used the same technique. Works fine. I use a woodworkers bench vise, so the jaws are lined with hardwood. Just do it BEFORE you paint the shaft. BTDT.
Old 04-09-2013, 07:44 AM
CadetTY's Avatar
So i should paint the shaft and spring after there put together? I do wana paint my clutch before it goes back in.
Old 04-09-2013, 09:04 AM
sawdustdad's Avatar
putting the shaft in a vise to compress the spring will scrape some of the paint off.
Old 04-10-2013, 06:33 AM
CadetTY's Avatar
Parts are gettin ordered today
Old 04-10-2013, 07:32 AM
mmzullo mmzullo is offline
don't paint the shaft by the clutch and spring!!!
Old 04-10-2013, 07:20 PM
CadetTY's Avatar
Lol its getting painted after everything is back together
