Followed your suggestions and the 1650 and myself couldn't be happier with the ending result. While in the N posission, I told it to stay, and it did without making a sound. Actually an easy enough adjustment, but I need to be told in cub talk, not from a page from a manual, hard for me to understand sometimes, that CRS is really catching up on me. So thanks for all the imput, on an easy fix. ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Glad to hear you got it figured out there Todd! Now next time it's your turn to be the Expert!
Keep dragg'n em in. They're like orphans...they all need a place to call home. |
Glad you got it, Todd!
I can sympathize with Todd. The manual's description of how to do the neutral adjustment is pretty cryptic. I, too, was confused about how to do it. Once you do it, though, you realize how easy it is. But, as others have said, it's a "hair trigger" adjustment. Very minor changes have a big effect. I did it on my 1650 but I still need to do it on my 149.
just finished this adjustment this afternoon on my 1650. Now I can lock the brake pedal down without a loud whining from the hydro and the tractors tendency to creep is gone. Now for the hundred other things left to figure out.
Dave
![]() Good luck on the other 100 things
Thanks Todd, I'm sure I'll need it. Took care of 2 more this afternoon.....got the ags mounted.
I have read the procedure for adjusting the cam bracket for creep. I have adjusted the hydro control rod to achieve full travel forward and reverse. I have adjusted the brake connecting rod to try to achieve neutral from both forward and reverse. I can adjust it to bring it to neutral from forward and it will not bring it to neutral from reverse. I can adjust it to bring it to neutral from reverse and it will not bring it to neutral from forward.
The link to the above instructions alludes to this problem but suggests no solution. I have spent hundreds of dollars in the last couple of weeks on this 1512 for missing and worn parts so I am not opposed to spending a few more dollars to replace worn out parts. Should I begin by trying to find a replacement for the 703-0198 Cam Assembly? and if that does not do it try to find a replacement for the 703-0194Plate Assembly (if an alternate is available)? Is it possible to replace the pin in the 703-0200 Control Rod? Should I ignore this problem since the brake is unnecessary except for parking? |
