Todd looks great!
Good looking Cub! Too bad CC don't build em' like these any more.
Not any more, long gone, but not forgot, rebuild em'
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
With these tough little tractors being made for longevity it seems odd that IH forgot to put a drain plug on the Diff Housing someplace. A maintenance Fluid and filter change should not warrant pulling the back casing.
When I first got my 782 there was so much moisture in the Diff that there was no movement when the temps went below freezing. Yes, needed to open it up and dry it out. Now, I just want to drain and change for maintenance reasons. Add the fact I put a 2" receiver/ hitch on the back and now it becomes a bit busy for a fluid change. .
If I can't fix it , it must not be broken |
I thought I saw something that might be a drain. Is it a four sided plug? Maybe fits a 1/4" or 3/8ths Open end wrench?
Maybe the reason behind no drain plug is, you had to remove the cover for fluid change, then you can clean out the inside.
![]() Cause you know how a lot of people are, "easier the better". And that's not always the best attitude to have. And if you only needed to open/remove a plug, the inside would never get clean or opened until there was an issue...
Nice Job Todd!! Pretty cool that it still had the IH filter on it in nice shape!
Id be tempted to drain that and keep it for display!![]() You may already know but the blue and white Car Quest filters are actually a premium Wix with a different paint job... just like a Napa gold! I use them also with no issues. Paint looks nice too!! ![]()
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
The clean way to do that job, not even a drip, we give you the Mr Clean award Todd!
By the way...I know no one notice but all pictures are dated from 2013! That camera may need to be set apparently.PS: We can see a old plank bench in one of the pictures, this is where I like to stand in all garage I had the chance to visit, I bet this one have a lot of good story to tell.
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
