Old 03-21-2013, 10:43 AM
Sounds like your headed in the right direction.
BTW I hate oil leaks.
Old 03-21-2013, 11:15 AM
PaulS's Avatar
PaulS PaulS is offline
Welcome as you can see most of us here keep things on a lighter note. In addition to seal replacement be sure to change the tranny filter too with the proper replacement filter. Do not use a regular oil filter. If it were mine I would be sure to clean any gunk (technical Term) out which you knew of course. I highly recommend HyTran as a replacement fluid. Yes it is more expensive than the clones out there but does the best job on encapsulating moisture to keep water out of your system.
Old 03-21-2013, 11:21 AM
Welcome to OCC! Good luck with your 149!
Old 03-21-2013, 04:07 PM
84Buckeye 84Buckeye is offline
Thanks for the link Sam. I like to get as much 'information' as possible before I start tearing into something. Will definately check that out!
Funny you mention Chicago. I thought all the IH Cub Cadets were built in Louisville, Kentucky? Mine has Chicago, Illionois on the rear seriel number tag.
Yes, I already bought 2.5 gallons of Hytran, $44,. rear gasket $8, and the cub filter was $18. Stuff sure is expensive, but I figure it's worth it. Ok to use carb or brake cleaner inside getting it all nice and clean?
Thanks again guys for all your help. Couldn't pass on this tractor. Really wanted a 169, but just can't find them around anymore it seems. And the price was so right with this 149. Someday I have every intention of doing a complete tear down/restore.
Old 03-21-2013, 04:40 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
I'm pretty sure all cub cadets were built in Louisville. Corporate HQ was in Chicago so that's why it says Chicago.
Old 03-22-2013, 01:50 PM
That is correct.
Old 03-22-2013, 03:47 PM
There is a wealth of information available on this site, and everybody seems so easy going! Refreshing! Thanks all for the help.
Old 03-23-2013, 12:49 PM
Thank you for becoming a member. We're here to help and encourage your yellow and red fever.
Old 03-23-2013, 08:27 PM
Glad you like it here! Everyone is great!
