Old 02-27-2013, 10:14 PM
Originally Posted by BillMorgan147 View Post
I used the electric-hydraulic system from a car convertible top. These parts are from a Dodge K-car, but it think similar or even the same parts are used in other makes and models.
The reservoir, pump, motor section is shown in one picture. I only used one of the two cylinders from the car. Mounting the cylinder was a bit of a hassle since it mounts at the rod end, and doesn't have the typical mounting on the cylinder end like most hydraulic cylinders.
Great job!
Old 03-04-2013, 04:07 PM
jkier's Avatar
jkier jkier is offline
Here are a couple of pics of the mockup.
Still need to figure out a float setup, thinking a slotted lift bar
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 03-04-2013, 04:34 PM
vartz04 vartz04 is offline
What did you do with your lift handle? just cut it off? or did you get the new rockshaft for the hydro/elec lift
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 03-04-2013, 04:35 PM
jkier's Avatar
My 147 came with the factory electric lift.
I just replaced the actuator
Old 03-04-2013, 04:42 PM
bummer. I knew that pic made it look to easy. Thanks for the pics of how it was set up though.
Old 03-05-2013, 10:41 AM
Cutting the lift handle is the easy.
Old 03-27-2013, 10:48 AM
chief's Avatar
chief chief is offline
I built this last week to lift my rototiller and it works great, I put it on one of my craftsman, I just got this week a 1650 & a 104 cadet, when I get them running I will put the tiller on one of them,
Old 03-27-2013, 01:12 PM
Great job!
