Old 02-25-2013, 09:53 AM
red56turbo's Avatar
Originally Posted by mmzullo View Post
I've watched a lot of tractors with duals on the upper side of the tractor(left). As it is the out side of the first tire barely hits the ground unless it's real soft. The only benefit the second tire would do is more weight maybe more stable. Most of the time the diff gets caught up on the tip of the furrow. I find it's better to have taller tires.
There are a lot of different theory's of this. I've plowed with a model 70 with 8.5's with no problems except the diff getting caught up. Traction was never really a problem.
Is it plow day yet!
I totally agree.
The outer tire tends to not even touch the ground. No help with traction. More a weight thing. Or a neat/cool factor.
Josh
Diesel Cub Cadets...........
Old 02-25-2013, 11:56 AM
Shaner Shaner is offline
or build a sweet onland plow and run duals on both tires and be the boss of the plow day.
Old 02-25-2013, 12:05 PM
With my old 806, when it starts to slip a bit, the inner wheel digs in somewhat, then the outer duel is on the ground picking up the load and it helps with traction and stops the slipping. (Only run duel on non furrow side while plowing)
I can't load the outside duals, as lifting near #1000 is not accomplished manually, I would have to use the loader tractor.
But I do see a good benefit of using duals, especially when disking (both wheels are dueled) as it provides more floatation and less wheel slip occurs, if any.
I also use duals on the JD 730 when pulling the planter, as it produces less compaction and a more even planting depth.
Yes, I'm talking a bit larger operation here, but the principles are the same.
Old 02-25-2013, 12:32 PM
jbrewer's Avatar
jbrewer jbrewer is offline
I totally agree.
And an axle housing bushing/bearing accelerated life tester!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 02-25-2013, 10:14 PM
cubcadet128 cubcadet128 is offline
Originally Posted by Jumper View Post
cubcadet128: What do you mean? Looks like they drop down in pretty good to me. (Sorry Scotty)
Haha I like this. It looks like my tractor after following both a Kubota and a John Deere with 12 inch plows that were plowing really deep.
Old 02-25-2013, 10:16 PM
I know, what you mean. I've had that problem too, plowing after the bigger JD tractors.
