Old 01-27-2013, 02:28 PM
rusmart rusmart is offline
Got some updates.
-Fixed the steering column. Took it apart and found the upper bearing in pieces and all over the place. The lower bearing shell was cracked. I guess someone really put some torque on it and broke it. Between the 3 'spare parts' columns I had, I put together a good one.
-Still working on the frame reinforcement. The last owner cut out some of the original metal and replaced it with some angle iron, but it was probably a quick job. I'm going to do a stronger reinforcement. I'll post pictures of what I'm doing when it's done.
-My engine does not have ACR (automatic compression release), I found one forum that said any k161 having a spec # ending in 'H' or lower does not have ACR. It only has 'retarded timing' to aid in starting. My k161 spec # ends in 'E', so I don't have it. I'm posting this just because I hate finding forums that don't have answered questions.
I've started the engine, and it doesn't seem that bad to start. I just used some twine wrapped around the pulley.
Quote from that forum:
"If the Spec # of your K161 has a suffix of "H" or lower, the engine did not have Automatic Compression Release (ACR) originally. .....If the cam was replaced at a later date, all bets are off. ....All K161's with a spec # ending in a letter higher than "H" were equipped with ACR.
The ACR consisted of a flyweight-activated pin on the exhaust lobe of the camshaft. ....At cranking speed, the pin would lift the tappet slightly to lift the exhaust valve slightly off its seat. .....Once sufficient rpm was reached, the flyweight would retract the pin, and the tappet would ride on the cam lobe.
The exhaust valve tappet was different for an ACR vs. non-ACR engine.
Whether or not the ACR is on your K-161, there is an ignition advance mechanism attached to the end of the camshaft. ....This too is activated by a different flyweight attached to the cam."
Russell
Cub Cadet Original w/ 3pt
Cub Cadet Original w/ fenders, creeper, & 3pt
Cub 100 w/ 3pt
Cub 125 w/ 3pt
NF Blade, cultivator, brinly plow, 38" & 42" deck, disc, tiller
Old 01-27-2013, 05:51 PM
Thanks for the update on your O.
Old 02-01-2013, 10:14 AM
Congrats on your O
Tags
original frame
