Old 01-11-2013, 09:58 AM
cub123's Avatar
cub123 cub123 is offline
I got my brake pad material from McMaster yesterday. I bought the 1.5” wide material because I’m lazy and didn’t want to have to make an extra cut. Part number is 6175K813 and it is 4’ long so I have enough left over to do another set of pads. Cost was $24.79 delivered. Cut the pads on my chop saw. This stuff cuts like butter with the saw. I did make the pads a bit larger than what came off the backing plates.
Well done Sam, you should have some stopping power now
Old 01-11-2013, 01:14 PM
Great job, Sam!
Old 01-11-2013, 03:56 PM
This the chop saw I used to cut the pad material at an angle on each end just so that I would maximize the contact area on the disk. Probably overkill.
Old 01-11-2013, 03:58 PM
Cleaned up the surface of the backing plates with a belt sander and then cleaned the surfaces to be glued together with lacquer thinner. Then I put a strip of freezer tape on the back side of the backing plate and one side of the pad so that they would not stick together.
Old 01-11-2013, 04:01 PM
I did 2 pads at a time. Mixed up the epoxy and put it on the pads. Next I put them in a vise and set them in front of a heater to cure. After curing I removed the tape and cleaned up the glue that had been squeezed out. A little touch up on the edges with the grinder and they are ready for paint.
Old 01-11-2013, 04:17 PM
Looks good Sam!
Old 01-11-2013, 10:05 PM
Looks good Sam!
What Mike said!
Old 01-12-2013, 11:31 AM
Probably overkill.
I think that happens a lot for you!
Old 01-12-2013, 12:24 PM
and your first clue would be? LOL
