Old 12-29-2012, 08:32 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
steve59, I love the tool box on the back.
Doug
Original , 100 , 125 , 582
Old 12-29-2012, 08:43 PM
steve59's Avatar
steve59 steve59 is offline
4SPEED....I just mounted it to a L-bracket and bolted it to a factory hole that was in the rear of the frame. Easy on, Easy off. I also put in Halogen headlight bulbs.
Chug a lug a luggin’ 5 miles an hour
On my International Harvester
Old 12-29-2012, 09:47 PM
4SPEED's Avatar
and it looks really good... I would need to use rubber washers so I didnt scratch the paint.
I know, I know...... im anal about my cubs.
Doug
Old 12-29-2012, 09:50 PM
steve59's Avatar
Ditto there 4SPEED ....My tool box is rubber washer mounted too!!
Old 12-30-2012, 11:56 AM
cubfixer's Avatar
cubfixer cubfixer is offline
While I had the tractor split, waiting on a replacement shifter, I installed these lights. The Grote is a repro, and the white light is a TSC light. Wanted a round one, but it didn't please me as well as the rectangular light.
Thanks for everyone's input, suggestions, and discussion!
Happy New Year to all!!
John
Old 12-30-2012, 12:10 PM
steve59's Avatar
Very Nice!!
Old 12-30-2012, 12:19 PM
That's nice, John!
Old 12-30-2012, 12:55 PM
BigB87's Avatar
BigB87 BigB87 is offline
thts a good set up. i have rear light on my 86 for plowing at nite time. **i have plowed late at nite just to make the neighbors mad** mine is plugged into the factory harness with a fuse and toggle switch but its only key hot so key off its off
Brandon
CC models: 86, 1650, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1978 1650 Hydrostat w/44" mower & 42" IH push blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 12-30-2012, 06:05 PM
sawdustdad's Avatar
Here are the lights I put on my 108. The tail lights are switched with the headlights and the backup up light is separately switched. It's not in the best spot, but I took the easy way out and bolted it through the hitch hole so I didn't have to drill a hole.
Old 12-30-2012, 07:01 PM
Muzzy Muzzy is offline
nothing wrong with that. Looks good.
