Old 11-07-2009, 01:42 PM
ajgross ajgross is offline
Inactive Member
Matt thanks for the reply. I hadn't thought about unseating a bead. That would make sense. I don't have any of my filled tires with tubes in them, but maybe I'll start.
jbollis, none of my tires have Calcium in them. I refuse to use that stuff. Like you said, it eats rims. All of my tires have "Rimguard" in them. It's made from beet juice, biodegradable, freezes at -40 degrees, and weighs 11 pounds per gallon, plus non-corrosive. Also it's approved as animal feed. If I spring a leak and loose my fluid, it won't hurt anything. That's why I haven't been using tubes.
AJ
Old 11-07-2009, 01:43 PM
Inactive Member
Sorry. Double post.
AJ
Old 11-07-2009, 02:28 PM
aagitch's Avatar
aagitch aagitch is offline
I'm also using rimguard with no tube since it's harmless.
Old 11-07-2009, 02:31 PM
I wouldn't even put CaCl2 in a tube...Dad's Farmall B has one tire with the stuff in it, in a tube, and the rim is junk.
Old 11-08-2009, 07:47 PM
Mountain Heritage's Avatar
Just wondering....what is the difference in weight between Rimgaurd and Calcium? Which weighs more?
Old 11-08-2009, 07:55 PM
RPalmer's Avatar
RPalmer RPalmer is offline
I think Rim Guard. I wanted to try it but I can't find a dealer....
Old 11-08-2009, 07:58 PM
I never even heard of Rim Gaurd before tonight? So you mean to tell me if I go to the feed store and get a bag of beet pulp and add water and mix it up in a big pot I will have my own version of Rim Gaurd??? lol..... I didn't think so!
Old 11-08-2009, 10:03 PM
jbollis's Avatar
jbollis jbollis is offline
As far as weights go . calcium chloride is about 11.8 pds per gallon. And rim guard is ( per there web site ) 10.7-11 pds per gallon. The problem with rimguard is finding a dealer close enough. And the calcium will only hurt your rim if it leaks. Problem is tubes tend to stick ( seal ) themselves to the rim, making it hard to tell when they leak. It only takes alittle calcium to do allot of damage to steel.
Sold everything but one.
Old 11-09-2009, 10:18 AM
MFP8055 MFP8055 is offline
I added the washer fluid to my 23x10.50-12 tires Saturday. The chart claims that 7 gallons would fit. Maybe this is so based on total volume, but the best I could do was 4.5. the tire was mounted with the stem at 12:00. Tubes were in the tires and they were brand new and hence, a little stiff. Anybody ever get more than that amount in a tire? How did you do it?
IH 1650, CC 1210, 1610 and Bolens 1257
Old 11-09-2009, 06:44 PM
aagitch's Avatar
Maybe you could drive it a little while like it is and then try to add some more
