Old 11-24-2012, 08:50 PM
Originally Posted by ihcc104 View Post
So grade 8 bolts have the same shear strength as spirol pins?
They are likely stronger but will wear the hole in the coupler and driveshaft because they are not a tight fit in the hole. They used spirol pins for a reason...
Old 11-24-2012, 08:52 PM
Sam Mac Sam Mac is online now
If I didn't have to be able to remove it I'd use the spirol pins, they fit the bore a bit tighter and my 71 will never see much hard work. It's just a play toy. It may pull a lawn seeder.
Old 11-24-2012, 08:55 PM
Looks like Matt and I posted about the same time with about the same answer.
Old 11-24-2012, 09:00 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Spirol pins it is! Lol, do either of you know if you can use the pins that are just 1 round of steel instead of the spirol looking ones? I can't seem to find spirol ones any place other than CC.
- Cory Sanderson
Old 11-24-2012, 09:12 PM
Mid West has them
Spiral Driveshaft Pin 1/4” X 1 1/2 “ Long
Priced Individually
Prt No. SP1 $1.85
I think I remember Matt had a place to get them even cheaper.
Old 11-24-2012, 10:30 PM
fullpull9 fullpull9 is offline
Default MWSC couplers
Those are great, we use them in our pulling tractor. We also just use grade 5 bolts instead of 8's. They are a little softer which lets them give without snapping under great load. Also it does help to slide a 1/4 punch in to help line everything up first and then drive it out with the pin or bolt. They do make special punches for these, the have a small dimple on the end to help it stay centered on the pin. Midwest does have a lot of good stuff some is good for stock mowing the lawn stuff too. They have kevlar clutch disc replacements that are quite nice as well.
Old 11-25-2012, 12:23 AM
EarlJ's Avatar
EarlJ EarlJ is offline
Just curious, any idea why the creeper has the breather extension? The rebuilt one I bought has the stubby factory one.
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 11-25-2012, 06:54 AM
McMaster Carr is a good place to get the coiled spring pin.
I get them from there and buy them in a 25 piece bag.
I can't seem to find the part number right now though!
Old 11-25-2012, 08:48 AM
ihcc104's Avatar
Well I Looked online and since I am using it on a NF, I will need an extension on the handle and breather to get up and out of the frame... I was under the impression that I would need an extension... I figured if it wasnt suppose to stick up as high that there wouldnt be a hole in the frame for it, am I wrong?
- Cory Sanderson
Old 11-25-2012, 11:00 AM
All of the 10 HP and above HP tractors have a high tunnel cover the only exception is the 100 it has the low tunnel cover.
