Old 11-14-2012, 08:42 PM
Do you have a multi meter? If so, Need to do some volt drop tests to find the culprit. A fluttering solenoid could be many things but inputs and out puts need checked. Not too bad to do. Volt drop test will isolate if its control or power circuit and then you can narrow it down to take the guess work out of it.
Old 11-15-2012, 10:27 AM
105_Tom's Avatar
105_Tom 105_Tom is offline
Also check the 3-wire harness connector to the ignition switch. These CAN and do go bad and can be sneaky to catch - take it off CAREFULLY and make sure that the 3 wires are not corroded at the connection point and that the plastic head of the socket is not burnt/cracked/broken from 40 years of use. I have had bad sockets on my 105, 147, 782 and a corroded wire on another that put up too much resistance to send proper voltage and current to the soleniod.
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 11-19-2012, 12:04 PM
OldPACubFan's Avatar
OldPACubFan OldPACubFan is offline
Thanks Alvy:
Looks like I'm going to learn more about using that multi-meter. When I get it back up and running I'll know more about the tractor than I knew yesterday.
Alan in Birdsboro, PA (OldPACubFan)
1972 model 149 - was my father-in-law's tractor
1973 model 149 - the first one I purchased
Also have a QA36A snow thrower
Old 06-05-2013, 12:59 AM
Smile Started - now to see if we can repeat it
Okay, so 6+ months later I decided I was going to give the tractor one more assist with a jump start from the car before calling for help/service. Pushed the hydraulic buttons down, shoved the tractor out of the barn hooked up jumper cables and it turned right over. This after nothing but clicking selinoid until then. Ran it for about 90 minutes and put it back in the barn. Battery test 5 volts after several days on charger, yup dead-er. New battery goes in tomorrow and we'll see if it'll run like new. Sure was nice to be mowing.
Old 06-05-2013, 10:52 AM
MBounds's Avatar
MBounds MBounds is offline
Buy yourself a new battery....
Myron B
East Texas
Most of of the fleet:
Cub Cadets: 2 Orig,70,71,122,123,104,124,126,86,128, 109,800,1200,1250,1450,1650,IH 682,782D,IH 982. Cadets: 76,SO76,80,81,IH 182. RER: 60,75. Elec 95. Trailers: #2, #3, #4, 1200-A,1200-B,1200-C, 2000. IH 1210 P/U, an IH Scout II and an IH Scout 800 to tow 'em with.
Old 06-05-2013, 05:05 PM
Yup, Cubs are notorious for eating batteries IMO.
