Old 10-16-2012, 09:11 AM
badboy1950 badboy1950 is offline
Originally Posted by Grand Pops 1810 View Post
is #26 cast inside the throttle bore? Thanks!
yes, look inside past the choke plate at the top.
the numbers stand proud of the surface .
Dan
Old 10-16-2012, 09:40 AM
FWIW:
I agree with replacing the Walbro, I never liked them.
You might try removing the bowl and cleaning things up a bit, and you may fine it helps or even works ok.
It would only cost your time if you are careful with the bowl gasket/flange gskt.
then you could take a little time to find the carb you want that is adjustable.
Sometimes just a little crud plugs things up.
Luck!
Old 10-16-2012, 10:36 PM
Grand Pops 1810 Grand Pops 1810 is offline
Okay, that sounds like plan A, give the Walbro a cleaning and inspection to see if it will run right. And in the meanwhile, start looking for a #26 (plan b) to have one on hand if/when I decide to bail on the walbro.
