Old 09-30-2012, 11:05 PM
brentwd's Avatar
brentwd brentwd is offline
Next I tackled the dashboard. This is what I started with. It came out pretty good considering it took 3 attempts to get it right.
Old 09-30-2012, 11:15 PM
Looks great!
Old 09-30-2012, 11:26 PM
brentwd's Avatar
Here is one of the problems it had. The input shaft was badly worn, so it had to be replaced before I put the creeper on. Next was getting the little stuff painted.IMG_0175.jpg
Old 10-01-2012, 12:07 AM
Looks great! That input pulley is pretty bad.
Old 10-01-2012, 07:14 AM
nikster's Avatar
nikster nikster is offline
Why is your hood-BLACK?
Did you use a rust reformer? Or is your primer black?
Nik,
Old 10-01-2012, 07:38 AM
Looks white to me, it's just the lighting (or lack thereof) in his shop.
Old 10-01-2012, 05:47 PM
Donovan M.'s Avatar
its white just cant see it.
Donovan:
62' Original-fenders
Old 10-01-2012, 07:32 PM
tractordude tractordude is offline
[QUOTE=brentwd;152799]Here is one of the problems it had. The input shaft was badly worn, so it had to be replaced before I put the creeper on. Attachment 29039
you can fix them by putting a Bronze "pin" in the hole, and weld the worn spot
Old 10-01-2012, 10:26 PM
brentwd's Avatar
Nikster, the hood and grill shell are painted case IH white, it's just the light. Tractordude, I went ahead and relaced it with a good used one. Talk about a seal that is hard to find and when you do it is so expensive.
Old 10-01-2012, 11:01 PM
brentwd's Avatar
Next came the fender pan and rearend to be painted. Boy did it take alot of paint. Quart and a half of mixed paint and this. If only I could keep those d#@& bugs out of the paint.IMG_0271.jpg
