Old 10-01-2012, 08:24 PM
Originally Posted by jdroison View Post
i would love to have a tig. I am good with a mig, and fair with stick. can usually fix anything I break except aluminum. I will have a welder I know look at it.
My son is going to welding school next year, wish he was already there they have just what we need for this.
If you clean it for him, do NOT use brake cleaner. High temperatures turn the brake cleaner into phosgene gas and can cause permanent lung damage or death.
http://www.brewracingframes.com/id75.htm
If you have a handheld mig gun ( 2 lb spool ), you can MIG it with a different inert gas. ( straight argon? )
I've also stick welded aluminum but you better be good. The aluminum stick "burns" extremely quickly and requires preheating to well over 350*F with a torch.
Old 10-01-2012, 08:51 PM
jdroison jdroison is offline
Exclamation
oh yes, I know about phosgene gas, same thing you get when halogenated refrigerants burn. been doing refrigeration for 20 years. I once had to crawl out of a small room, lit the torch to fix a leak and there was still enough in the air I could not breath. drug the torch out with me and sucked on the oxygen side for 20 minutes. came real close to passing out that time it hit me so fast, always had a fan with me after that one.
