Old 09-05-2012, 10:13 PM
red56turbo's Avatar
Default Melted wire on 1250.
Just picked up a nice, original 1250. PO said it had an electrical problem and he hadn't looked into it, otherwise it ran great. I believe him seeing he was a very honest 85 year old. Anyway, pulled off the tank and found my problem. Someone did some shade tree wiring and replaced half of the wire from the ignition switch to the coil with a butt connector. No big deal with the connection. The problem is the whole wire from ign. switch to coil is melted to the point the insulation is falling off and the wire broke. I did a temp wire together and got it to start and she runs great. Probably will replace the wire for now till I can get a different harness.
Anyone have any idea why the wire would get so hot to the point of melting and breaking. Only the coil wire was affected. Key left on, overcharged battery, bad coil, break in insulation allowing grounding?
TIA for any ideas. Hate to put her back together and fry something else or even worse, catch it on fire.
Josh
Diesel Cub Cadets...........
